size of dictionary?
Re: size of dictionary?
By the way can you reproduce the bug you mentioned? I don't get it anymore with this new word list...
goodie
Phone: Samsung Galaxy S
Post by goodie »
Yes, I get the same bug
생각ㄷ suggests 생각된 생각도 생각돼 생각될 생각되다 생각되고 ...
but
생각도 or 생각되 suggests nothing.
Similarly,
하게 sugguests 하겠다 하겠고 하겠어 ...
but
하겠 suggests 하객 only
Another bug I see is the syllable-final consonant ㅎ changed to ㅍ.
파랗다 is suggested as 파랖다
좋다 is suggested as 좊다
놓다 is suggested as 높다
I checked the wordlist I've sent, and it was okay, so there must have been some error in converting into dictionary.
OK I will look at these problems (quite a pain to investigate but I have to...)
goodie
Post by goodie »
It seems that there's a problem with syllable-final consonant.
Just as 좋다 is suggested as 좊다,
같다 is also suggested as 갘다.
(같 is 갘+1 in Unicode. 좋 is also 좊+1 in Unicode)
When I type 간+ㄱ, it becomes 갉, (it should have been 갈+ㄱ)
and when I type 간+ㅅ, it becomes 갌. (should have been 갈+ㅅ)
Thank you very much for all the extra steps you take for Korean support!
Indeed there was a bug in the dictionary converter with some final consonants! It's fixed now. I also understood the other problem, but it's more difficult to fix
Ok, so I fixed all the problems you reported! (hope I didn't introduce new ones...) Can you test with the latest dictionary?
goodie
Post by goodie »
Wow, works great!
Thanks a lot!!
By the way I published it to the market, let me know if you see other problems so that I can fix. And thanks for your work!
