Wrong suggestion
Re: Wrong suggestion
No... I would need to flash CM (I don't have time at the moment) to check this problem myself, because I can't understand how that's possible
About the long press, it's on purpose.. it displays a 0 and another character (I don't know why but I saw that on other keyboards too ;) )
inoam
Phone: hero
Post by inoam »
That sign is for ILS (israeli shekel) it's never used :)
About the other bug I'll gather some patience ;)
So I installed CM and indeed reproduced this problem. Now I will try to understand it!
Not sure why it didn't work, but anyway I found a workaround which seems to fix the problem, so this will be in the next version
mattan
Phone: HTC Desire
Post by mattan »
I am using Hebrew keyboard, and the "RTL suggestions" doesn't work for me (both marked or unmarked).
All the suggestions appears reverse.
Any solution?
Which ROM are you using?
