I've figured out a possible workaround to the shift+ issue. I use a Kensington bluetooth keyboard that has alt+option buttons. I discovered that if I press the alt+option button before I type, I can shift select...example
3333333333333333@#$#@#$#@#$#@#$@2343222345364324345#$%345#$%#$%$#
Be advised this is a relatively crude fix...this is still a bug that should be addressed by Cyril.
Shift and Ctrl keys don't work on external physical keyboard
jjohnsonmarine
Re: Shift and Ctrl keys don't work on external physical keyb
Does anybody know if this issue has been resolved?
Today, I found the answer. Try MultiLing Keyboard (https://play.google.com/store/apps/deta ... atin&hl=en). It is free, versatile and takes care of the couple of issues that Smart Keyboard had, which its developer has neglected to solve, including this very issue. With MultiLing, the shift/ctrl keys work as they are supposed to.
Goodbye Smart Keybard Pro, and welcome MiltiLing!
