Text issue with Copilot
gubbero
Phone: Motorola Milestone
Re: Text issue with Copilot
Post by gubbero »
Thanks for the update !!!!
Great work
// Suzpel
diabolikoo
Phone: htc legend 2.1
Post by diabolikoo »
Thanks for the update but I have the problem with htc legend android 2.1 and last SMP...:( how can i resolve?
Froghut
Post by Froghut »
I'm using version 2.4.1 but I still have the same problem in Copilot - auto suggest is enabled but doesn't get disabled when in copilot. I have a german system, perhaps that matters?
What is exactly the version of copilot from the market you are using? (there are several ones)
killeriq
Phone: Xperia X10 1.6
Post by killeriq »
facing the same problem, using CoPilot Live 8.2.0.218, typing extra letters
im using the smartkeyb 3.5.0
any new fix on the way? thx
Actually it's already fixed since yesterday ;) (in the beta of the next release)
The problem is that Copilot changed the name of its package, so Smart Keyboard was not able any more to detect it
killeriq
Post by killeriq »
cyril wrote:Actually it's already fixed since yesterday ;) (in the beta of the next release)
coool ;)
sinan
Phone: HTC Wildfire Android 2.2
Post by sinan »
Hello,
I have the above issue with my
HTC Wildfire with Android 2.2
Copilot Live 8.2.0.218 and
Smart Keyboard Pro 3.14.0
I have already tried both the workarounds mentioned above but did not work.
Any idea how to get over this?
Have you tried to disable "always suggest" option?
Can you enable debug logs in the advanced settings, and find a line starting with "Called from package" in your phone logs (you can retrieve them with "Log Collector" app) when you show the keyboard in Copilot?
sinan
Post by sinan »
Yes, I have disabled the "alvays suggest" option, it didnt help.
And in the logs, there are some lines as follows:
02-28 21:49:01.371 D/SmartKeyboard( 172): onFinishInput
02-28 21:49:01.371 D/SmartKeyboard( 172): onStartInput: restarting=false
02-28 21:49:01.401 D/SmartKeyboard( 172): onStartInputView
02-28 21:49:01.401 D/SmartKeyboard( 172): Called from package com.android.vending
