Where's the pound (£) symbol?
Re: Where's the pound (£) symbol?
There is a simple solution: define a custom autotext to replace "d" by "£", and that's all!
Cyril, that seems a bit of a pain to be honest.cyril wrote:There is a simple solution: define a custom autotext to replace "d" by "£", and that's all!
How difficult would it be to create an English (British) locale with £ being the prominent currency symbol?
I'm not saying it's difficult (I could do this for the next version)
I'm saying there a solution NOW to your problem
and it's even better than long pressing the d key as you just need to press "d" and you have your pound! (do you ever type the word "d" alone?)
Thanks Cyril.cyril wrote:I'm not saying it's difficult (I could do this for the next version)
I'm saying there a solution NOW to your problemand it's even better than long pressing the d key as you just need to press "d" and you have your pound! (do you ever type the word "d" alone?)
I was thinking more long term for new users finding £ instantly than having to knowing they have to create custom autotext.
If you could look at bringing something into the next version, that would be stunning.
Utterly amazing Cyril. Works a treat having a new language "English (uk)".cyril wrote:Fair enough, I added it in the latest beta
If only every author was so quick to take onboard comments and action.
People who run regularly know the advantages of running. Also do they know the importance of good shoes when running. There are different multinational companies manufacturing shoes currently, however not all shoes are worth spending for. Onitsuka Tiger Monte Pokhara shoes have caught the imagination of all runners, and are said to be the best available option currently for running. High quality Onitsuka Tiger Olympos must the most perfect shoes.
