Keyboard disappearing
Re: Keyboard disappearing
By the way I think this should be fixed in 1.2.4, but anyway tell me if it happens again
I still see this happening with 1.3.0. The following is a snip from the logs, which contains the same output every time I experience this bug. Dunno if this will help or not.
02-11 18:58:40.219 W/InputManagerService( 74): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@44c6aaa8
02-11 18:58:41.799 D/dalvikvm(31475): GC freed 3796 objects / 248088 bytes in 153ms
02-11 18:58:43.759 D/dalvikvm(32186): GC freed 11230 objects / 794656 bytes in 60ms
02-11 18:58:44.039 D/dalvikvm(32186): GC freed 3946 objects / 449592 bytes in 250ms
02-11 18:58:44.439 D/dalvikvm(32186): GC freed 7104 objects / 742104 bytes in 81ms
02-11 18:58:44.579 W/IInputConnectionWrapper( 74): showStatusIcon on inactive InputConnection
02-11 18:58:44.589 I/ActivityManager( 74): Starting activity: Intent { act=android.intent.action.MAIN cat=[android.intent.category.HOME] flg=0x10200000 cmp=com.android.launcher2/.Launcher }
02-11 18:58:44.849 W/InputManagerService( 74): Ignoring hideSoftInput of: com.android.internal.view.IInputMethodClient$Stub$Proxy@44d76df8
02-11 18:58:44.859 V/RenderScript_jni( 132): surfaceCreated
02-11 18:58:44.859 V/RenderScript_jni( 132): surfaceChanged
02-11 18:58:44.869 V/RenderScript( 132): setSurface 480 762 0x63ee58
No !!!!!!!
Can you send me the whole logs ?
But at least the other bug (when too much text is entered) is fixed, right ?
Full log sent!
And no, I have not seen the keyboard get stuck since yesterday's fix.
Thanks.
Unfortunately I removed the debug logs which would have been useful to understand why the keyboard is hidden... I will re-add them in the next version (it will be an option)
OK, so I added some logs in 1.3.1, I hope this will be enough to understand the problem.
Can you enable the new option "debug logs" in the advanced settings ? Then you can send my the logs (with Log Collector) if it happens again, and the exact time it happened would help me (as there will be many logs)
Thanks !
Thanks !
