multi touch sometimes doesn't work
Re: multi touch sometimes doesn't work
Out of curiosity, do you have issues with multitouch with the stock keyboard too? Or is it even better to have no multitouch at all (I can't see why it would be better, so it's interesting to know)
avatar5d
- Phone: Nexus One
Nope, I have absolutely no glitches with the stock keyboard. I've also used Swype and the HTC IME and have never had any problems with those either.
I'd prefer to use SKP because it's the fastest and has the most features.
nick.koutrelakos
- Phone: Motorola Droid 2.0.1
This same issue is present on the HTC Incredible (which doesn't surprise me, considering it has a similar screen to the Nexus One). Please fix it, if you can, cyril. I love SKP...
goldee
- Phone: HTC Incredible
Same issue here on an htc incredible.
atmu
- Phone: incredible
I just posted a new topic with the same problem under the title "keyboard lag, cannot type fast." I'm having the same issue on Htc incredible. I've switched to ShapeWriter for now because of it. The stock Htc keyboard does not have this issue but it sucks for other reasons.
If this issue gets fixed SKB will be back to default
So, now that Google finally sent me that Nexus One, I can clearly see the problem. I am working on a fix
Ok, so the reason is clear. If you type for instance "hahahaha" very fast with two fingers, android may tell the keyboard that you start to press on "h", and release your finger on "a" (i.e. it doesn't even see that there are two fingers involved), so it only displays "h", as if you moved one finger quickly from h to a. I will try to work on this, but as far as I can see the android keyboard doesn't behave better at all in this situation
nick.koutrelakos
On my Motorola Droid, SKP works flawlessly. On my HTC Incredible, it has this problem... clearly there can be a fix..?
There is a workaround to this touchscreen bug in the Froyo stock keyboard. I am not 100% happy with Google's implementation of the workaround, but I will try to integrate something similar as soon as possible (it requires a bit of testing)
WillJitsu
- Phone: EVO 4G / Android 2.1
Multitouch is not working at all for me on the EVO 4G. Is this a known issue on this phone as well?
