[REQ]Ice Cream SandWich Keyboard?
c00ller
Phone: HTC Hero CDMA
Re: [REQ]Ice Cream SandWich Keyboard?
Post by c00ller »
Pressed keys look good, and the shift key symbol looks like the right size now :) . My delete symbol still looks disproportionately large compared to your screenshot, though. Also, this is very minor but could you verify if the shift lock color is supposed to be green and not blue?
Yes, I'm sure : the shift color is green in the SDK, and not blue...
It was already the case under Honeycomb, but I never updated my skin to a green version. I just didn't like it ;-)
Anyway, in the attached one, I reduced the backspace, and I added both green and blue pictures (you just need to open the zip, and you can choose your pictures)
PS : My screenshot is taken from the ICS SDK, not from my phone ;-)
ICS-SDK.zip
(71.66 KiB) Downloaded 1004 times
Hi, can you make this for mdpi? I tried the skin you attached and the buttons are very very thick so you can't barely hit them IT'S really ugly and unusable... Thanks
4tonmantis
Post by 4tonmantis »
just when i got excited to try it out i find out its hdpi lol all the buttons are super small on my phone and the background is 3 different colors like a black, brownish black, and dark gray(grey?)..anyways an mdpi version would be great if you would do that :D
4tonmantis wrote:just when i got excited to try it out i find out its hdpi lol all the buttons are super small on my phone and the background is 3 different colors like a black, brownish black, and dark gray(grey?)..anyways an mdpi version would be great if you would do that :D
it is already mdpi... check out the content of the zip from your computer.
what is your phone model ? maybe it doesn't allow many colors on its screen ?
new update
here is the skin :
ICS-SDK.zip
(71.7 KiB) Downloaded 1512 times
and here are the PSD source files :
Ice Cream Sandwich.zip
(13.94 KiB) Downloaded 963 times
(note : for ldpi/mdpi, set the symbols width to ~24px)
where I can set symbols width ? I found only height...
Gnaver wrote:where I can set symbols width ? I found only height...
using photoshop, for edition of the PSDs.
4tonmantis
meyergre wrote: it is already mdpi... check out the content of the zip from your computer.
i have 2 at the moment an optimus v(currently using) and a samsung continuum(i forgot how to spell it), both of which have really small keys and a choppy background. oddly enough a few of the hdpi skins on here show up really well on my ov, so i figured if this was hdpi it would come out fine, i swear i saw hdpi on here somewhere lol but since its actually mdpi i dont know whats wrong :(
Well, the skin has both mdpi and hdpi pictures inside the .ZIP, and it's the android system on your phone whe decides which one to use.
you can force mdpi, if you remove the drawable-hdpi folder from the zip. Anyway, a screenshot would be helpful for me ;-)
