Resurrected Skins [Updated to Black Suggestion Bars]
- Phone: Droid X 2.2
Re: Resurrected Skins
I've only had the time to update the 3 pink ones to a black suggestion bar. Maybe I'll have time later to make purple ones.
Re: Resurrected Skins [Updated to Black Suggestion Bars]
Gloss purple for the girlie girls.
- GlossPurple.zip
- Black Suggestion Bar
- (41.25 KiB) Downloaded 1916 times
- GlossPurple.png (61.46 KiB) Viewed 27269 times
For the not-so-girlie girls...or the dudes with a sensitive side.
- GlossPurpleMod.zip
- (40.67 KiB) Downloaded 1887 times
- GlossPurpleMod.png (56.59 KiB) Viewed 27269 times
...and for the dudes keeping their sensitivity underwraps (or the girls looking for a skin just for them).
- GlossBlackPurpleLined.zip
- (41.26 KiB) Downloaded 1969 times
- GlossBlackPurpleLined.png (57.88 KiB) Viewed 27269 times
kctony
these are without question some of the best skins I've ever seen! Is it too much to ask you to do a blue chromatic skin similar to the red or green?
It was already in the making. Hope you like it.
- BlueChromatic.zip
- (61.41 KiB) Downloaded 2185 times
- BlueChromatic.png (71.66 KiB) Viewed 27254 times
kctony
that's what I'm talking about! Fantastic!!!
Copper...might remind you of a Duracell battery.
- Copper.png (72.7 KiB) Viewed 27231 times
- Copper.zip
- (63.08 KiB) Downloaded 1959 times
It was requested (with much ferver I might add) that I make the pink skins more pink. So, I did. Even though the colors are more pink than the fuchsia color before, I titled these "Magenta" to keep confusion down. This one might look so subtle, you won't necessarily notice the difference until the keypress image shows.
- GlossBlackMagentaLined.png (57.16 KiB) Viewed 27230 times
- GlossBlackMagentaLined.zip
- (39.97 KiB) Downloaded 1931 times
Last edited by yhwhsupports on Sun Aug 14, 2011 12:12 pm, edited 2 times in total.
It's more apparent here:
- GlossMagentaMod.png (56.69 KiB) Viewed 27230 times
- GlossMagentaMod.zip
- (40.39 KiB) Downloaded 1814 times
