Can something like this skin be done? cost? thank you
CAO
Re: Can something like this skin be done? cost? thank you
Post by CAO »
Can the keyboard be made with iphone keys?
CAO
Post by CAO »
Can the keyboard be made with the iphone keys or the layout?
Iphone skin is not made the same way, it has been written within the application's code. It's not yet possible to get the same result with a custom skin. Nevertheless, you can edit the keys height in the settings, so you gan get closer to what you want.
If you want the same graphics, try the Cupertino skin somewhere on the forum ;-)
EDIT :
Maybe you'll prefer this one ;)
UKbd2.zip
(18.51 KiB) Downloaded 536 times
CAO
Post by CAO »
At first, I noticed the buttons looked to be a pale blue instead of white and the background was not as blue as in the first two keyboards, but in using this one, I think the colors are better and absolutely amazing. I love the spacing on the keys. I wish I could design the keyboards like you do, but when I run the program, it crashes the computer. Maybe its a VISTA thing. In any regards, you did a great job, and I appreciate it.
Which program are you using ?
CAO
Post by CAO »
Handcent and Docs to Go.
CAO wrote: wish I could design the keyboards like you do, but when I run the program, it crashes the computer. Maybe its a VISTA thing
CAO wrote:Handcent and Docs to Go.
I meant to draw the pictures for the skin ;)
CAO
Post by CAO »
When I try to download the "Android " open skin to begin, the Internet Explorer opens then immediately closes then does this repeatedly without stopping. I cannot get the computer to stop, and I have tried control, alt, and delete but to no avail. The Internet Explorer opens and closes so fast the task manager cannot keep up with it. I wish Smart Keyboard had an easier way to customize the keyboard. Ultra Keyboard is no where as good as Smart Keyboard, but one can adjust everything with regards to key colors, backgrounds and letter colors. I cannot understand why the keyboard developers have not tried to put this in the settings. The instructions for customizing Smart Keyboard is rather confusing to a person who is not computer savy. Swiftkey is the worse for lacking in customization. Perfect Keyboard is getting really good.
If Internet Explorer become crazy, try using Firefox, Opera, Chrome, or whatever
Don't forget to scan your computer with an antivirus program too ;)
Anyway : you don't especially need the "Android" skin, you can do the same with any other one (the one a few posts ago for instance ;))
CAO
Post by CAO »
No luck. I downloaded Goggle Chrome and Opera, but the Internet Explorer takes over when I try to open a particular skin, and shuts the internet on and off so rapidly the computer has to be shut off. I still wish Smart Keyboard had a better way of customizing the keyboard in the settings menu like Ultra Keyboard and Perfect Keyboard does.
