Thanks! Although I'm not too happy with the blue one...
As to the "Keep them comin' ": I won't be able to do further modifications before this weekend.
But if there are any suggestions please tell me.
Darkgreen and Darkorange skin
tls
- Phone: Samsung Galaxy S II - Android 2.3.3
newdeepdan
- Phone: Samsung Epic 4G
Re: Darkgreen and Darkorange skin
I really love this skin. Can you make one this gold color? Hex #FFD700
tls
Sure! I was thinking about a somewhat yellow version anyway.
May be I'll be able to do it today, but no promises.
My last one would be baby blue and datz it for me
tls
I've managed to do the 'Gold'-Version today. Technically it's yellow with a little more red than green but it's the color 'newdeepdan' asked for, referring to it as gold.
Besides 'gold' sounds better than 'yellow'
@PrettyGrlSwag26
I'm sorry but as I mentioned earlier I'm rather busy this week and todays spare time was consumed by the Gold-skin.
I might be able to do the baby blue on Friday but I will definitely do it on Saturday.
It would be nice if you could deliver me a specific color code, as the previously made DarkBlue skin has already some bright blue colors.
Hm, it seems that the DarkPink-skin is the least popular even though it's my favorite! Guess I'm losing my Y chromosome
@PrettyGrlSwag26
- DarkGold by tls.zip
- (67.94 KiB) Downloaded 994 times
- DarkGold_prtrt.jpeg (182.6 KiB) Viewed 15543 times
Ok thanx!
newdeepdan
THANK YOU SO MUCH! and such a fast response! I'm still in shock! thank you thank you thank you a billion times over!
Edit: I tried installing these skins on my tablet (Galaxy Tab 10.1) and it didn't work. Anyone out there that can help? Using the default installed skins are fine though.
tls
As promised, here's the (hopefully) DarkBabyBlue skin. I hope it's near to what PrettyGrlSwag26 asked for!
@newdeepdan
I'm sorry I can't help you but I do not own an Android tablet nor can I imagine why this isn't working.
@newdeepdan
- DarkBabyBlue by tls.zip
- (66.23 KiB) Downloaded 920 times
- DarkBabyBlue_prtrt.jpeg (175.11 KiB) Viewed 15506 times
twins0190
Is there a way to change the number keys (?123) to just a white font myself? I'm using the Darkgreen skin and the font color is white, and I dont use the alt keys above the letters, so I would like to change the ?123 to white as well.
tls
Yep, there is a way it's pretty easy. Unzip the 'Darkgreen.zip' open up the 'skin.xml' with Notepad/Editor/Whatsoever and search for
this string:
<colors>
<label bold="true">#FFFFFFFF</label>
<alt-label>#FF82B600</alt-label>
<mod-label>#FF82B600</mod-label>
</colors>
then change to:
<colors>
<mod-label>#FF000000</mod-label>
</colors>
Then save the skin.xml and zip it up with the two folders 'drawable' and 'drawable-hdpi' - Bring the Zip back to the skins folder on your phone and you're finished!
this string:
<colors>
</colors>
then change to:
<colors>
</colors>
