quesstion do you can check mine skin it not showing up whit the skins on mine phone ..
Skins! Request!<3 C:
yakie996
- Phone: htc widfire 2.3.4
Re: Skins! Request!<3 C:
super!!!! it works!!
- yarni theme.rar
- (14.64 KiB) Downloaded 1552 times
yakie996
i found it. it was a .rar but it shows black (like the normal skin 'black') and not the colors dat i had...yakie996 wrote:super!!!! it works!!
edit do someone can make this?? https://market.android.com/details?id=m ... rch_result
- meyergre
easy, your files have twice their extension.
for example, your XML requires a normal.9.png file, but in your drawable folder, all you have is a normal.9.png.png one
2 ways to solve the problem :
- Go in your folders settings, under control panel, and UNcheck "hide known extensions"
- or, just remove the extension you added once more
but I personally prefer the 1st bullet
Like it ? buy me a beer
- meyergre
Don't you have a market access on your phone ? this skin seems to be downloadable for freeyakie996 wrote:edit do someone can make this?? https://market.android.com/details?id=m ... rch_result
yakie996
i it compatibel with smart keyboard??meyergre wrote:Don't you have a market access on your phone ? this skin seems to be downloadable for freeyakie996 wrote:edit do someone can make this?? https://market.android.com/details?id=m ... rch_result
- meyergre
According to the author, it is.To apply, open Better Keyboard/Smart Keyboard settings console, choose Skin/Theme.
- Phone: Samsung Moment, Acclaim, and Galaxy S
Yes. Any Better Keyboard skin is compatible, unless it's by the developers of Better Keyboard.yakie996 wrote:i it compatibel with smart keyboard??
yakie996
I did the 1st bullet but is still not working..meyergre wrote:easy, your files have twice their extension.
- meyergre
then just remove the 2nd extension on each of your files, once you unchecked the box, you should be able to see them. all your files finishes with ".png.png" instead of ".png".
After that, if it's still black,then the problem should be somewhere else...
yakie996
always black --'meyergre wrote:then just remove the 2nd extension on each of your files, once you unchecked the box, you should be able to see them. all your files finishes with ".png.png" instead of ".png".
