Touch to replace is buggy
Re: Touch to replace is buggy
Indeed, but in that specific case, you can just do a backspace, and then touch to correct will insert a space as you expect.
swrobel
- Phone: HTC Evo CM7
in what specific case?cyril wrote:Indeed, but in that specific case, you can just do a backspace, and then touch to correct will insert a space as you expect.
swrobel
Oh, thanks, good tip! Ok, that solves that one, although when I do that, the issue still exists that when I insert the space again, it gives me the choices from the previous word rather than punctuation or nothing.
Probably you enabled the option "ignore hard keyboard". It has to be used ONLY for the droid pro!Lycox wrote:I tried to install the latest beta but after installing the SKP doesn't pop up. Beta from 2011-06-04 maybe 3rd works fine.
Lycox
- Phone: HTC HD2 - Android 2.3.3
Thanks for the hint. Works nowcyril wrote:Probably you enabled the option "ignore hard keyboard". It has to be used ONLY for the droid pro!Lycox wrote:I tried to install the latest beta but after installing the SKP doesn't pop up. Beta from 2011-06-04 maybe 3rd works fine.
Hello, this issue should be fixed in the latest beta; can you check?swrobel wrote:Oh, thanks, good tip! Ok, that solves that one, although when I do that, the issue still exists that when I insert the space again, it gives me the choices from the previous word rather than punctuation or nothing.
