Can someone post the non-bold zip here? The bold is a bit too much for me on my Thunderbolt. Otherwise... This is BY FAR the best SKP skin of all time imo! I love the Honeycomb look and feel!!!
Sent from my ADR6400L using Tapatalk
Honeycomb skin
N1des
- Phone: DX 2.2.1 Stock Rooted
- meyergre
Re: Honeycomb skin
Yup, you can download it on the 1st postN1des wrote:Can someone post the non-bold zip here? The bold is a bit too much for me on my Thunderbolt. Otherwise... This is BY FAR the best SKP skin of all time imo! I love the Honeycomb look and feel!!!
EDIT : I just tested it on my Nexus One (2.3.3) and NI Adam (2.2) : it works. In addition to the thin letters, the last link has been graphically updated (CAPS LOCK button's light)
Like it ? buy me a beer
N1des
Re: Honeycomb skin
OMG! This is sweet! I'm using it now - it looks perfect. Great job, and thank you so much!
- AndroidGX
Re: Honeycomb skin
Hi there !
Just registered in this board to comments your beautiful work.
Finally a great honeycomb skin, that was time !
The skin is almost perfect, I just suggest to use real honeycomb colors (screenshot HERE) instead of "bluewish" heys.
The shift key desserves a bit larger blue led I guess, like the screenshot shows it too, otherwise it's an overall very nice skin, many thanks for your hard work!
- meyergre
Re: Honeycomb skin
Yep, i'll do it this afternoon
- AndroidGX
Re: Honeycomb skin
Nice mate, many thanks, hope to see that but take your time if needed
- meyergre
Re: Honeycomb skin
That's very nice, thanksAndroidGX wrote: Just registered in this board to comments your beautiful work.
Finally a great honeycomb skin, that was time !![]()
Just doneAndroidGX wrote: The skin is almost perfect, I just suggest to use real honeycomb colors (screenshot HERE) instead of "bluewish" heys.
You're right, thanks for the screenshot. It seems to be around 1/3 of the key... Well, mine is about 1/2 for now, but I'm getting even closerAndroidGX wrote: The shift key desserves a bit larger blue led I guess, like the screenshot shows it too, otherwise it's an overall very nice skin, many thanks for your hard work!
New release on the 1st post
- AndroidGX
Re: Honeycomb skin
Fantastic work that you just released, many thanks!
All seems ok so far now, maybe 1 more critic : the caps, return, 123, back etc keys are still dark blue instead of beeing dark gray.
Many thanks again mate for your work
- meyergre
Re: Honeycomb skin
I really don't know what you mean ...AndroidGX wrote: the caps, return, 123, back etc keys are still dark blue instead of beeing dark gray
- AndroidGX
Re: Honeycomb skin
Sorry, I try to be more clear
Remember the screenshot I provided of the honeycomb keyboard here ?, for exemple the color of the shift key on your skin is dark blue, on the real honeycomb keyboard, it's dark gray as you can see
Do you see what I mean now ? if not don't hesitate to tell me, I will try to explain better with pleasure
