glowkey (colors: blue, red, green, honeycomb!)
Re: glowkey [colors: blue, red, green!]
mylenthes wrote:Woot
The blue doesn't match honeycomb very much
I didn't intend it to. The blue was based off of the Swiftkey tablet skin.
mylenthes
Phone: g2 with honeybread
Post by mylenthes »
Oh, well I hope you make a honeycomb colored one inthe future.
mylenthes wrote:Oh, well I hope you make a honeycomb colored one inthe future.
I'll try, what's this 'honeycomb' color?
mylenthes
Post by mylenthes »
#ff586991 is one code that was posted in the honeybread thread.
4b61a2 is the one I made for launcher pro as it uses a different code type. You should mess around though to see what you like.
Red's up!
mylenthes wrote:#ff586991 is one code that was posted in the honeybread thread.
Thanks, this helps me with my work. I'll do both, send you a PM with betas. I can't do it right now or tomorrow, but maybe next weekend.
dan55
Post by dan55 »
blue on blue is AWESOME! :-) love it
many thanks for all your hard work
cheers
dan
Microsoft
Phone: Samsung Galaxy Tab Android 2.2
Post by Microsoft »
WoOoW .. It's Very nice :shock:
I hope make another one with a gray color .. Pleeeeeeeeease ;)
7Stringer
Post by 7Stringer »
The actual lettering seems a bit fuzzy compared to other skins, almost as if it isn't hi-res. Overall, though, it looks and operates nicely. I like all the color choices. I'm running it on a DX, by the way.
mylenthes
Post by mylenthes »
Ok, to save you some time I edited the file myself to suit honeycomb better. You can edit it and fix anything I may have broken and add it to your main posts if you like.
Honeycomb.zip
(48.6 KiB) Downloaded 1472 times
