[UPDATED] MIUI_black1.2 (webOS skin)
7Stringer
Re: MIUI_black (webOS skin)
Post by 7Stringer »
Ah, much better. Thanks for the fix - this really helps. I like the shading and black background. Personally, I'd even prefer a slightly smaller key, but I also like the iphone-style keyboard a lot. I'd be willing to pay ya to do a slightly smaller key.
Oh, and no graphics issues. The fade is really nice - the keys have a great 3D effect. I find typing on it very easy.
7Stringer wrote:Ah, much better. Thanks for the fix - this really helps. I like the shading and black background. Personally, I'd even prefer a slightly smaller key, but I also like the iphone-style keyboard a lot. I'd be willing to pay ya to do a slightly smaller key.
A good skin dev shouldn't make his work into paid apps- unless it's a multiple skins-in-one deal and updates it frequently. Or, at least, that's my standard :)
Here is your version w/smaller keys (it's the non-transparent one):
MIUI_black1.2_smallkey.zip
(42.95 KiB) Downloaded 3738 times
7Stringer
Post by 7Stringer »
Ah, this is much more my style. Thanks for the consistent reworking of the skin - I can get used to this one haha.
Thanks for the hard work.
7Stringer wrote: I can get used to this one haha.
Does it need to be a bit smaller...?
7Stringer
Post by 7Stringer »
If you're up for it, I'll gladly check it out. Perhaps slightly increase the gap on the top/bottom, too? Not just side-to-side?
christianojeda
Phone: droid
Post by christianojeda »
TheTehk17 wrote:
christianojeda wrote:looks great! thanks!
Curious, I don't have HDPI, how does it look on your phone? Any graphics bugs?
Nope everything seems to be working great!
The graphical bug with MIUI_black1.2_smallkey is now fixed. Users with that skin, please update using the file above ^^^
7Stringer wrote:If you're up for it, I'll gladly check it out. Perhaps slightly increase the gap on the top/bottom, too? Not just side-to-side?
Sorry, was busy for a while. Anyways, I increased the top/bottom distance, and fixed a major graphical bug- everything should now be crisp and clean. The file is updated a few posts above this one ^^^
As always, just tell me if there's anything wrong!
hummerbr4
Phone: droid x gingerbread
Re: [UPDATED] MIUI_black1.2 (webOS skin)
Post by hummerbr4 »
How do I install it to where I can use it to type with? I can't figure it out please p :D lease answer me
hummerbr4 wrote:How do I install it to where I can use it to type with? I can't figure it out please p :D lease answer me
You will first need to create a folder in your SD card named skins. You can do this with any file manager, such as Astro or Androzip.
Then, download this skin using the links on the first post on the first page of this thread. After that, use the file manager to copy the skin into that skins folder you created.
To use, open settings<keyboard<smart keyboard<general<select skin.
