I am having a problem when I select the georgian language all the keys on the keyboard show up as blocks instead of the respective symbol.
I have the latest version of Smart Keyboard
Sony Experia X10I with android 2.1 firmware.
What is the correct procedure to get the Georgian language to work?
Thanks in advance for your help.
Georgian Language problem
foolsrwe
- Phone: Xperia unknown
Re: Georgian Language problem
you need to install a font supporting Georgian, which is not the case in stock Android ROMs. But you have to root your phone... (check this for instance).
