How to Convert WMV to MP4 on Mac
goonsnoopy
Phone: 2.0
Post by goonsnoopy »
What kind of Mac WMV to MP4 Converter should we choose?
If we want to find a video converter to convert WMV to MP4 on Mac, what we consider about is quick and efficient video conversion, the converted video quality and easy operation. Here we recommend an excellent professional Video Converter for Mac. It is a powerful and practical video converter which can easily convert between a variety of video and audio formatsin your desire.
Armed with a succinct interface and fast conversion speed, it makes the WMV to MP4 conversion quite simple. And the quality of the output file is extremely wonderful. Thus you can have a better enjoyment of your MP4 videos or movies made from WMV file on your iPod, iPhone, PSP, etc.
Note: If you are a Windows user, please go to the Video Converter for Windows guide for more information.
How to convert WMV to MP4 on Mac?
To save your precious time, we make a tutorial about how to use Video Converter for Mac in details as below. Just few steps can finish the conversion with loss-less quality feature and superb fast conversion speed.
Step1. Add WMV files to the program
You have two ways to import files.
1. Click "File" item on the tool bar to add files.
2. Conveniently drag videos to the program. (Batch conversion is available too.)
Step 2. Choose MP4 output format
Because you need to convert WMV to MP4, so you should choose MP4 as your output format in the "Format" list as below.
Step 3. Edit the video
BeforeWMV to MP4 conversion , you can edit your videos by trimming, cropping, adding video related subtitles and watermarks to make your output videos perfect and unique. You just need to click "Edit" icon shown in picture 1 or click "Edit" item on the tool bar to make the edition.
Step 4. Convert WMV to MP4
After you make all the editions, you just need to click "Convert" button on the bottom right. Then it will come to the conversion interface. You can set "Put computer to sleep" or "Shut down my computer" mode in the "After conversion" option.
Other features:
1. Before WMV to MP4 conversion, you are able to set video and audio parameters like codec, resolution, frame rate, bit rate and so on by clicking "Options" item in the "Output Setting" menu.
2. Supported OS: Mac OS X 10.5, 10.6 or 10.7(Lion)
Related Articles:
--1. How to Convert AVI to iPhone on Mac.
--2. How to Convert AVI to DivX on Mac.
--3. How to Convert AVI to FCP on Mac.
