How to Convert FLV to AVI on Mac
When it comes to FLV format, most people are familiar with it. Because of the small size and high upload speed, FLV Video has been accepted as the default online video format by many sites such as YouTube, Google Video and so on. However, most media players and portable devices don’t accept FLV videos. In order to solve this problem, we need a FLV to AVI converter to make the conversion. Here we have a Video Converter for Mac which can make the conversion on Mac with high speed and superb quality.
Note: Below tutorial is for Mac users. If you are a Windows user, please go to the Video Converter for Windows guide for more information.
How to make FLV to AVI conversionon Mac?
Download and install the program, you will find that making conversion just need a few steps.
Step1. Import files to the FLV to AVI Converter
You can just directly drag the files to the Video Converter for Mac. Or you can click "Files" on the tool bar to import files.
Step 2. Select AVI as your output format
In the ''Output Setting'' menu, you can select AVI as your output format in the "Format" list.
Step 3. Set video parameters
Before FLV to AVI conversion , you can adjust the video and audio codec, resolution, frame rate and bit rate by clicking “Options” item in the output setting menu.
Step 4. Begin FLV to AVI conversion on Mac
After set all the pamameters, you can start conversion by clicking "Start" button.
Tips on FLV to AVI Converter for Mac:
1. Video Converter for Mac supports Mac OS X 10.5, 10.6 or 10.7(Lion).
2. Previewing is available before conversion.
Try to make FLV to AVI conversion now!
Related Articles:
--1. How to Convert Torrent to AVI on Mac.
--2. How to Add SRT to DVD on Mac.
--3. How to Convert MTS/M2TS to MPG on Mac.
