How to Convert FLV to MOV on Mac
“I downloaded a movie and it’s in FLV format. How do I convert it to MOV or any other file that can be played on my iPod and on Mac?”
For the reason or others, you need toconvert FLV to MOV with the Video Converter for Mac. This converter can help you to convert video to any other formats within high speed and quality. Even you can edit the video freely with this powerful and professional tool. This software provides an easy and quick way to convert almost all popular format video to Mac-compatible format. The output file can be played on iPhone, iPod, iPad, Apple TV, iMovie and so on. It’s a really easy to use and convenient tool to complete the conversion.
How to convert FLV to MOV on Mac?
Here we go to the tutorial of converting on Mac for example. And if you need to convert on Windows, you can go to the Video Converterguide for more details.
Just several steps and clicks are needed to get over the conversion.
Step1 Download and run the program directly.
Find the downloaded DMG file in your library and run it directly, you will see the software as below:
Step 2 Import files to the converter to prepare the FLV to MOV conversion
Drag and drop the FLV files to the main screen of the converter. Also you can choose to load file in the “add new file” of the File on toolbar.
Step3 Choose the output format as MOV
Find and choose the MOV format under the list of Common Format. Even you can set the format by the model of your portable devices, and the converter will help you to convert to format that compatible with your devices or software perfectly. For example, you can choose iPhone, iPod, iPad from Apple Devices, iDVD, iMovie from Apple software, Android, BlackBerry from mobile phones, and PSP from Game console.
Step 4 Convert FLV to MOV
After doing 3 steps above, you just need to click the “Start” to start the conversion. And the converter will show you the MOV files to you when the conversion is completed in few seconds.
Tips for better url=http://www.league-soft.com/how-to/conve ... v-mac.html]FLV to MOV conversion[/url]:
1, This is a program designed for Mac 10.5 or above (Lion included).
2, You can see the estimated size on the main interface of the converter and decide whether it is worthy to convert.
3,This software provides you a convenient way to capture the screen when you preview the original video.
Try toconvert FLV to MOV now or get more info of theVideo Converter for Mac:
Related Articles:
--1. How to Convert MPEG to VOB on Mac.
--2. How to Convert YouTube to AVI on Mac.
--3. How to Convert YouTube to MPG on Mac.
