Easily How to Convert VOB to AVI on Mac
litingtingsmile
Phone: 135903961062
Post by litingtingsmile »
How to Convert VOB to AVIon Mac
Why should you convert VOB to AVI?
As we all know, VOB file is a movie data file from a DVD disc, always stored in the VIDEO_TS folder. The VOB file includes almost all of the data stored on the disc like video, audio, and subtitles. Since the releasing of DVD early in last century, it become a popular movie container and widely used all around the world. But it’s a pity that the majority of media player don’t support the VOB files. So what should you do if you want to enjoy the excellent DVD video on Mac? The answer is converting VOB to the format compatible with your media player like AVI.
What should you do if you want to convert VOB to AVI on Mac?
You need a Video Converter for Mac. This Video Converter for Mac is the best video converter for Mac users. This software can convert any video format to another. When you start the conversion, you will find it’s really easy-to-use and converting at a high speed. This is a guide for Mac users. If you need to convert on Windows OS, you can go to the Video Converter guide for more details.
Step 1 Run the program
Download and run the VOB to AVI Converter for Mac
Step 2 Import the VOB file
Drag the VOB files you want to convert. Or you can choose to follow the steps as below: Menu > File > Import > Add Video Files. Multiple conversiong tasks can be converted at the same time.
Step 3 Select the format as AVI
Click the output setting icon to set the output format. Find the AVI under the list of “Common Video”
Step 4 Start the VOB to AVI conversion
Click the “Start” to start the conversion Step 5 Send the AVI video to your portable devices
This converter will show you the output folder automatically, then you can send it to your devices or enjoy iton you Mac. Tips on VOB to AVI Converter:
1 You can preview the VOB file on the built-in displayer and snapshot the scene you favor.
2 You will see the editing function when your cursor slips to the thumbnail. You can trim, crop the video as you wish.
3 It’s a program designed for Mac OS X 10.5 or above.
Extend knowledge of VOB
VOB (Video Object) is a media container format that contained in DVD disc. It’s an MPEG-2 system stream complies with the MPEG-2 system level standard. The Video, Audio, Subtitle, and Menu are included in stream form.
Try to buy now to get more details about the VOB to AVI Converter for Mac.
Related Articles:
How to convert WMV to AVI on Mac.
How to convert YouTube to AVI for Mac.
How to convert VOB to MP4 on Mac.
