How to ConvertMPG to AVIon Mac
Why should you convert MPG to AVI?
If you are PSP or Xbox 360 users, you may find that your device doesn't work well with MPG files. That's because that both PSP and Xbox 360 don't support MPG format video but AVI. To enjoy MPG files on your devices, you'd better convert MPG to AVI. Numerous converters can be found online, but most of them are really awful as the converted files are low quality.
Now, with the help of Video Converter for Mac, you can convert the video in high speed with the same quality. Not only convert video to video, but also this converter allows you to extract audio from video. What's more, you can easily edit the source video. For example, you can trim any part you want, crop the screen to the most suitable size, adjust video settings and add watermark.
How to use this MPG to AVI Converterfor Mac?
This is a guide for Mac users. You can go to the Video Converter guide if you are a user of Windows. Only few clicks are needed to accomplish the conversion.
Step 1 Launch the Video Converter for Mac
Step2 Load the files to prepare the MPG to AVI conversion
A convenient way allowed by this converter: drag and drop the files to the main interface. Or you can choose the File option on the Menu and select "Add Video Files" under the list of Import. Several conversion tasks can be run at the same time. After importing files, you can preview them with the built-in player on the right of the interface.
Step3 Choose AVI as the output format
Click the "output settings" and find the AVI format under the name of "Common Video". If you are convert MPG files for you portable devices, you can also set the output format as PSP, Xbox under the name of "Game Console" or iPhone, iPod under the name of "Apple Devices".
Step4 Convert MPG to AVI on Mac
Three prepare steps have been done, and then you just need to click the “Start” button to get the AVI video. Conversion can be accomplished in a few seconds.
Tips for better MPG to AVI conversion:
1 This is a version designed for Mac 10.5 or above (Lion included).
2 Taking a picture is a good choice while you previewing the video.
Try to convert MPG to AVI now or get more info of the Video Converter for Mac.
Related Articles:
1. How to convert MP4 to AVI on Mac
2. How to convert MP4 to MPEG on Mac
3. How to convert AVI to MPG on Mac
Easily How to Convert MPG to AVI on Mac
- Phone: 135903961062
