What are the main features of Video Converter for Mac?Can we find a video converter Mac which can not only make a perfect conversion from MOV to MPEG on Mac, but also can edit the video what I want?
Yes, of course. The Video Converter for Mac is just an ideal converter you need. The strong functions of this program are far out of your imagination.
For example:
▼ It supports to convert video and audio easily between a variety of popular formats.
▼ It supports to output movies and other videos to tons of portable devices.
▼ It supports to customize videos with a list of useful editing options.
▼ It supports to extract audios from music videos for use with MP3 players.
Note: Below we provide a tutorial is for Mac users. If you need to convert MOV to MPEG on Windows OS, please go to the Video Converter for Windows guide for more information.
How to convert MOV to MPEGon Mac?
Please safely download and install the program, and then try to make the conversion as below steps.
Step1. Load files
For your convenience, the MOV to MPEG converter allows you to directly drag files to the program. Batch conversion is also OK.
Step 2. Choose MPEG as the destination format
After you import files, you need to select the correct output profile. Now, you should choose MPEG as your destination format.
Step 3. Start MOV to MPEG conversion on Mac
Just click "Start" button, all the tasks will be done at fast speed and high quality.
How to edit video on Mac with customized features?
Please click the "Edit" icon, the "Video Edit" interface will appear as below.
Go to "Trimming" section, please click the scissors icon, you can move the sliders on the player bar or input the exact time index by yourself to determine the length.
Go to "Cropping" section, move the limiters of the dashed frame on the player window to remove black margins.
Go to "Video Adjustment" section, move the handlers to modify video brightness, contrast, saturation and audio volume.
Go to "Subtitle" section, you can choose “Load Subtitle” option in the Subtitle item to load video related subtitles.
Go to "Watermark" page, select an image or text file and use the positioning sliders to locate it on screen
Want to get Mac MOV to MPEG Converter now?
Related articles:
How to convert MPG to FLV on Mac.
How to convert MPG to MOV on Mac.
How to convert MPEG on Mac.
How to convert MOV to FLV on Mac.
How to easily make MOV to MPEG conversion on Mac
xnleague
- Phone: android2.5
