How to Convert MPEG to MOV on Mac
Why should you convert MPEG to MOV?
MPEG is a file format that supported by QuickTime. However, some Mac users find that when they enjoy MPEG video in QuickTime, only sound exists. Even sometimes, QuickTime crashed. Then what can you do? My suggestion is converting MPEG to MOV. As we all know, QuickTime supports MOV well enough. What’s more, MOV is supported by all Apple apps.
What you need is a Video Converter for Mac. It’s a program that can help you complete the conversion. You’ll find the conversion is so easy and cost only a few time. Besides converting MPEG to MOV, this professional software can convert between any video with another.
How to convert MPEG to MOV on Mac?
Here is the step-by-step guide lead you to complete the conversion on Mac. If you need to convert on Windows OS, you can go to the Video Converter guide for more details.
Step 1 Run the video converter for Mac
Download and run the converter directly.
Step 2 Add the MPEG files
Select the MPEG files you want to convert and drag them to the main interface. Also you can choose to Add Video Files under the Import list. Batch tasks are supported by MPEG to MOV Converter.
Step 3 Choose the format as MOV
Click the output setting icon, then you can select format by your portable devices or just “MOV” under the list of Common Video.
Step 4 Convert MPEG to MOV
Click the “Start” to start the conversion and the program will show you the output MOV file just after the conversion.
Tips for better MPEG to MOV conversion:
1 This is a version for Mac OS X 0.5 or above, if not, you have to update your Mac version.
2 You can extract audios from music videos with this software.
Try to convert MPEG to MOV now or get more info of the Video Converter for Mac:
Related Articles:
1. How to convert XviD to MOV on Mac.
2. How to convert MPG to FLV on Mac.
3. How to convert MP4 to WMV on Mac
- Phone: 135903961062
