How to Convert AVI to MOV on Mac
AVI is one of the most commonly used video format in our life. While MOV is the video format of Quicktime which is developed by Apple Computer. So, if you want to play a AVI video in Quicktime or on some portable Apple devices, you need to convert AVI to MOV .
In order to help make this conversion, we select an excellent program - Video Converter for Mac and recommend to you.
This program can convert between a variety of popular video and audio formats such as AVI, MOV, MKV, MPEG, VOB, MP3, etc. for playback on various portable devices like iPad, iPod, Apple TV, iPhone and so on. For better enjoyment, it provides users video and audio edit and adjustment funtions. With this program, you can enjoy almost all videos and audios without limitation. You can learn more about this program from the below tutorial.
Note: Below tutorial is about AVI to MOV conversion for Mac users. If you are a Windows user, please go to the Video Converter for Windows guide for more information.
How to make AVI to MOV conversion on Mac?
Step1. Load files to the AVI to MOV Converter
Open Video Converter for Mac and drag the AVI files into this program. Batch conversion is supported.
Step 2. Select MOV as the output profile
In the "Output Setting" menu, please chooseMOV as your output format in the "Format" list.
Step 3. Video setting
Before AVI to MOV conversion, you can set up the video codec, resolution, frame rate and bit rate by clicking “Options” item in the output setting menu.
Step 4. ConvertAVI to MOV on Mac
After pressing "Start" button, it begins to work with high efficiency
Notice for Mac AVI to MOV Converter
Related Articles:
1. How to convert AVI to Apple TVon Mac.
2.How to convert AVI to Quicktime on Mac.
3.How to convert AVI to iPad on Mac.
4.How to convert AVI to iTunes on Mac.
5. How to convert AVI to M4V on Mac.
cafayzieg
- Phone: 15818947470
