dictionary format?
hotaru
- Phone: htc hero cdma / cm 6 (android 2.2.1)
dictionary format?
what format are the dictionaries in? is there an easy way to convert dictionaries from the format that the normal android keyboard uses?
anyone may use and modify any smart keyboard skins that i post on this site.
you may distribute those skins or modified versions of them for free.
you may not sell any of my skins or any derivative works of my skins.
