Slide popup Keyboard - whats that for?
I have no idea, can s.o.explain.
10x
- PROXIMO
- Phone: Wildfire
Re: Skide popup Keyboard - whats that for?
Yes it was a bit difficult to explain in 3 words
It's an option to customize the behavior of the popup keyboard when you long press a key, when they are more than 1 alternative character.
If the option is on, you need to keep your finger pressed, and slide it to select the alternative character you want (like HTC keyboard)
If the option is off, you need to release your finger and press again on the alternative character to select it (like Android keyboard)
- PROXIMO
- Phone: Wildfire
ok i got it 10x
i was wondering for which popup keyboard comes into question.
May be slide popup alternative(s) is more acurate.
