How to Import AVI to iTunes on Mac
If you have an iPod, iPad or iPhone, you must be familiar with iTunes. It is a digital media management applications indroduced by Apple Inc. This program is used for playing, downloading, saving, and organizing digital music and video files on personal computers. However, it is incompatitable with some popular formats including AVI, WMV, VOB and so on. So, here we would like to provide a smart solution to teach you how to import AVI to iTunes on Mac. The professional Video Converter for Mac will help you make various conversions and editions with few steps at ease.
Note: Below tutorial is for Mac users. If you are a Windows user, please go to the Video Converter for Windows guide for more information.
How to import AVI to iTunes on Mac in detail?
Freely download the Video Converter for Mac here and please refer to the tutorial as below.
Step1. Launch the program and add AVI files in
Firstly, please run the program. You can conveniently drag the AVI files into this program. For your convenience, batch conversion is also available.
Step 2. Make edition with the customized features
Before you convert AVI to iTunes, you can make some editions through trimming, cropping, video adjustment, adding subtitles and watermark to make the output video more special. You can click "Edit" icon shown in picture 1, all the tasks will be finished in one interface.
Step 3. Select the correct output profile
After you make all the editions, you should click "Output Setting" icon and select your output profile in the "Format" list. It provides you various output profile options such as iPod nano, iPod touch, iPhone 3G/4S and so on.
Step 4. Start AVI to iTunes conversion on Mac
The "Convert" button is at the bottom right, please click it and all the tasks will be done at fast speed and high quality.
Tips on AVI to iTunes Converter:
1. This program can not only help you convert AVI files to iTunes, but also support to convert between a variety of video and audio formats.
2. Before the conversion, you can adjust the video and audio codec, resolution, frame rate and bit rate by clicking “Options” item in the "Output Setting" menu.
Related Articles:
1. How to convertconvert AVI to iPad on Mac.
2.How to convert AVI to Apple TV on Mac.
3.How to convert AVI to Mov on Mac.
4.How to convert AVI to Quicktime on Mac.
5. How to convertAVI to M4V on Mac.
cafayzieg
- Phone: 15818947470
