Im sure this is an easy question but I am not cell phone programing smart. So, Im turning to the good ppl of the forum to help.
My MIC button is gone. It was there before I did the last update and now, can’t find it. I do have language set to English and do have the option checked in setting. Still, no luck.
Any advice?
Veronica
Voice ~ Mic Gone?
Re: Voice ~ Mic Gone?
I don't see any reason for that, if you selected "mic key" in the options and the current language is English it should be there. Are you sure you use the latest version of Smart Keyboard Pro?
Can you long press 123 key? If you don't see "Smart Keyboard Pro Settings", it means you don't use Smart Keyboard Pro any more, which would explain the problem;) Then click "Help" and "About..." to check the version
nsrmom
- Phone: 936-556-5509
Did an uninstall and reinstall. It showed up then. I then did a backup and it went away agian? So, uninstall/reinstall once more. Have to redo all settings and words and all that stuff but ohh well, at least its back.
Hogan shoes are very comfortable. So girls, not just buying high heels, you can have a try to wear such luxury Hogan Newest Women Shoes. They are also fashion and luxury enough for you to show your own fashion taste. Hogan Women Dancing Shoes are also very fit you in summer.
