Smart keyboard pro 3.7.1- with english (international) and hebrew keyboards installed.
The soft keyboard works great, but the physical one won't switch to Hebrew. I tried checking and unchecking the "physical keyboard " option in the settings but it didn't seem to make a difference.
What am I missing here?
shift + space not changing language?
Re: shift + space not changing language?
Have you enabled the "physical keyboard" option? Anyway it will not work, as hard key translation is not (yet) implemented for Hebrew.
I can add this easily, but I need a picture of your physical keyboard
Hi and thanks for the quick replay. Enabling the option does not make a difference.
Here is a photo of the hard keyboard in devices similar to mine sold here: http://www.tgspot.co.il/wp-content/uplo ... estone.jpg
The only difference is that my device has the right menu key labeled with the menu icon instead of the language icon seen in the photo.
OK, so I implemented hard keyboard translation for Hebrew in the latest beta version.
Note that you need to press comma for TET letter, and shift+comma to get a comma
Can you try it?
Can you try it?
It is possible to change the keys that switch the language in the physical keyboard?
works fine, thank you! (And I think you mean the letter tav, not tetcyril wrote:OK, so I implemented hard keyboard translation for Hebrew in the latest beta version.
Can you try it?
