I'm a currently using Droid which has hardware qwerty keyboard,
and I'm trying to type Korean with hardware keyboard, but I've been unsuccessful...
I purchased Smart Keyboard Pro, and installed Korean keyboard add-on.
Enabled Smart Keyboard Pro in language/keyboard options, chose English and Korean in language selection key.
I tried Shift+Space key to change between langauges on hardware keyboard, but it doesn't seem to be working.
Hardware Menu key brings up menu for the note app that I was typing in.
I do not know if I missed anything...or maybe there's another way around to make it work.
I used to use Korean Hangul Keyboard (Beta) by Notes which supports hardware keyboard, and recently trying other keyboards
due to its double typing glitch on hardware keyboard. I hope ur keyboard works!
Thanks.
Different language input w/ hardware keyboard?
suoro
- Phone: Droid Cyanogenmod 6.0.0
Re: Different language input w/ hardware keyboard?
you tried too early
I implemented this feature 2 days ago, it will be in the next version (3.6.0) I will submit today
you tried too early
Version uploaded!
By the way you need to enable the new option "physical keyboard" to use this
suoro
I just tried ur update, and it seems like working seamlessly!
Thank you
Thank you
