Greetings,
I can not stand the default keyboard in Android becuase I keep hitting the "period" key when trying to hit the spacebar.
Can you remove or move the period key on Smart Keyboard PRO?
I've tried and purchased several other keyboards and can not find one that really works for my big thumb.
Any help is most appreciated and I will purchase your application if I can get rid of the period key!
Thanks,
Dan
Period key removal
Re: Period key removal
This would be a nice option, since double space is what I (and most people[?]) use for a period and the comma is already on the top bar.
Would certainly give a thumbs up to this suggestion. I'm always hitting . when going for the space bar.
If you could put space-space to = . then you wouldn't need the . key and increase the width of the space bar.
Whippetcat
- Phone: DroidX version 2.2
I see this has been done in Portrait. Can the option to remove the period also be given in Landscape? Thank you.
