How to Convert AVI to M4V on Mac
“Anyone know how to go about converting AVI to M4V, so i can use them on an ipod? I have tons of downloads from free torrents sites, but i can't get them to work on the ipod. Any help is appreciated.
Many people may have met the same question because Apple devices just support Motion JPEG (M-JPEG) up to 35 Mbps, 1280 by 720 pixels, 30 frames per second, audio in ulaw, PCM stereo audio in .avi file format. While M4V is high compatitable with Apple devices which is developed by Apple Company. So, if you want to play these downloaded AVI videos smoothly on an iPod or iPhone, iPad and so on, you need to convert AVI to M4V. We will teach you how to make the conversion at ease with a professional Video Converter for Mac
Note: Below we provide a tutorial for Mac users. If you are a Windows user, please go to the Video Converter for Windows guide for more information.
Detailed tutorial about AVI to M4V conversion on Mac.
To know more about this program, you'd better download and try to use the trial version to make the conversion as below.
Step1. Load files to the program
Launch the program, you can conveniently drag the AVI files into this AVI to M4V converter or you can click "File" item to import files. Batch conversion is also supported.
Step 2. Select M4V as the Output format
Click the "Output Setting" icon and select M4V as your output format in the "Format" list as below.
Step 3. Output settings
You are able to adjust the video and audio codec, resolution, frame rate and bit rate by clicking “Options” item in the output setting menu before AVI to M4V conversion .
Step 4. Start conversion on Mac
Just click "Start" button, AVI to M4V conversion will begin at fast speed and high quality. You are able to delete the files or stop the conversion during the process.
Notice on AVI to M4V Converter for Mac:
1. When you make the conversion on Mac by Video converter for Mac, you can click “Edit” icon to apply special features to the output video through trimming, cropping, video adjustments, add subtitle and watermark.
2. If you make batch conversion, you can set "After conversion" mode on the conversion interface. It provide "Put computer to sleep", "Shut down my computer" and "Do noting" three options for you
Related Articles:
1. How to convertconvert AVI to iPadon Mac.
2.How to convert AVI to Apple TV on Mac.
3.How to convert AVI to Mov on Mac.
4.How to convert AVI to Quicktime on Mac.
5. How to convertAVI to iTunes on Mac.
