How to Convert AVI to Quicktime on Mac
Sometimes, when you play a AVI video in Quicktime, you may meet format incompatible problem. That's not strange, because AVI is also in defferent codecs. Some types of AVI formats such as DIVX, AVID are not accepted by Quicktime. So, how to play these types of AVI videos smoothly in Quicktime? The best solution is to find a professional video converter and convert AVI to Quicktime supported formats.
Video Converter for Mac is an excellent program which can not only support to convert AVI to Quicktime, but also can convert between a variety of video and audio formats. You can convert these incompatible videos for playback on various portable devices like iPad, iPhone, PSP, Apple TV and so on..
What should we do to make AVI to Quicktime conversion on Mac?
For user's convenience, we provide a detailed tutorial as below. This tutorial is for Mac users. If you are a Windows user, please go to the Video Converter for Windows guide for more information.
Step1. Run the program and import files
Start Video Converter for Mac first. You can convenienly drag the selected AVI files to the program. You can also click "File" item on the tool bar to import files.
Step 2. Select the correct output format
Because MOV is Quicktime supported format, you can click "Format" item in the "Output Setting" menu and select MOV as your output format.
Step 3. Start AVI to Quicktime conversionon Mac
The "Convert" button is at the bottom right, please click it and all the tasks will be done at fast speed and high quality.
Tips on AVI to Quicktime Converter for Mac:
1. When you make the conversion on Mac by Video converter for Mac, if you want to edit video, please click “Edit” item or just click the icon shown in below picture. Then you can apply special features to the output video through trimming, cropping, video adjustment, adding subtitle and Watermark.
2. Before AVI to Quicktime conversion , you can adjust the video and audio codec, resolution, frame rate and bit rate by clicking “Options” item in the "Output Setting" menu.
Related Articles:
1. How to convertconvert AVI to iPadon Mac.
2.How to convert AVI to Apple TV on Mac.
3.How to convert AVI to Mov on Mac.
4.How to convert AVI to iTunes on Mac.
5. How to convertAVI to M4V on Mac.
cafayzieg
- Phone: 15818947470
