I'm thinking of buying the PRO version, in order to get Hungarian language support, but I have a question:
Does it mean that both HU dic and the HU layout (with about 10 accented chars) are available?
Just asking because in releasenotes it is said that HU is added on 2010/05/30. However, I cannot see the dic here: http://smartkeyboardpro.com/files/
And also a spanish guy is told on June 1st in the forum (cant put link here) that his accented chars were not available as separate keys on the layout, long after it had been announced
So are both things (dic+layout) included?
On Hungarian language support
Re: On Hungarian language support
there is hungarian layout, but no hungarian dictionary yet, but if someone helps me it's easy to create one
Ok, I understand.
In the meantime I checked some available Hungarian dictionaries on mobile keyboard but none of them were really good and also I found that in landscape with two fingers typing can be really fast so having no dic is not a big thing.
However:
- if I have Hungarian layout enabled am I able to use the English dic and add new entries to it?
- if there a feature in SKP that if I double tap a mistyped word anywhere in the current keyboard input area it replaces that with the best fitting dictionary entry?
- could you post a screenshot of the Hungarian layout please?
However:
Are you looking shoes for your family? Why not have a look on Tods 2012 New Style? They have superior quality and fashion style. Tods Mens Shoes are the perfect shoes designed for men.
