Color Dots appear after tapping letter on keyboard
Hi, Can anyone tell me how to stop the coloured dots (red and blue) that appear on each key as I tap it, showing exactly where I tapped. It's really annoying! Thanks for your help. Cheers
Re: Color Dots appear after tapping letter on keyboard
You can disable it in Settings>Language and Keyboard>Smart Keyboard. From there, I am not sure which section it is under but I know it is there.
Thanks for your reply. I wonder if you might know what the setting is called? I feel like I've been through every setting but can't see anything that might be it. Thanks again.
... >Advanced>Show touch points
