* Improved word picking in prediction bar
* Better performance for Chinese and Japanese
* ICS [Android 4.0] fixes
See? Just because an update took a while does not mean cyril abandoned SK
Users previously having issues: please update and see if your problems are fixed, then post whether they are or not in the bug report thread you started.
The bug from 4.6.1 when in compact qwerty layout and I am entering letters in the password field is not yet fixed. The preview only works for the first letter and afterwards, it can't be seen. When in normal qwerty layout, you can still see the letters typed and when you enter the next letter, that is the time that it will change to an asterisk (or to a big dot). Hope you can fix this. Smart Keyboard rocks.
