I have been using the trial for awhile and liked it so much that I bought the Pro version. I spent alot of time customising all the settings and adding custom dictionary words for my language (Afrikaans), Is there any way I can transfer all the settings etc from the trial to the pro version?
If it has been answerd somewhere else on the forum, please provide that link, as I cant find it.
Thanks,
Hardus
Transfer Data From Trail to Pro
Re: Transfer Data From Trail to Pro
HI All, been awhile and no one could answer me, I had to figure it out myself.
Just backup everything with the trial and then make a backup with the pro version also, open the file manager, on the phones's sd card, there is 2 folders, smart keyboard, and smart keyboard pro.
Replace the backup of smart keyboard pro with the one from trial.
I would have hoped by buying this app would get me some form of support, good app, bad support.
baldmosher
- Phone: Samsung Galaxy S2, Gingerbread
I found this thread in Google trying to figure it out.
Then I noticed they've already added an option to do this very thing in the Pro settings screen. (It's also there in the Trial settings too, although not sure how that would work...!)
