Can't Find?
juicyj
- Phone: Mytouch Version1.6
Can't Find?
HELP! I cannot find Smart keyboard on the android market!
Re: Can't Find?
Do you have Android 2.0 ? It needs this at the moment, but I will work on a backport to Android 1.6 (without multitouch) if possible
GAZ082
- Phone: Motorola Milestone AR
Re: Can't Find?
Could you post the apk for the free version? It's not in my Market (using Android 2.0.1).
Treehead
- Phone: Motorola Milestone 2.1 upd.1, O2DE
Re: Can't Find?
here too. I'm looking for something better than the usual android keyboard, have read a review of smart keyboard, but can't find it on the market. Using Milestone with 2.1
Re: Can't Find?
Please read the FAQ
If you cannot yet set the app in android market, you can also buy with SlideMe (http://slideme.org) meanwhile
Treehead
Re: Can't Find?
/edit: Just found you the trial version under /files. Looking forward to try it.
Unfortunately, I can only see the dictionaries for smart keyboard on the market, but no other products developed by you. Since the standard android keyboard is very suboptimal when it comes to special characters, I think that a lot of people are looking for something better. You could add a point to your FAQ that the trial version can also be downloaded under "/files". It doesn´t look very self-explaining at the moment. I overlooked the link there, because I wasn´t searching for dictionaries.
Re: Can't Find?
Actually the free version is not on slideMe, as you should see it on the market.
If you don't, you could try "Market Enabler" or you can download on the web site: http://android.cdeguet.net/files/
terenceleechan
Re: Can't Find?
hi cyril!
i love your app. i've been using the free version with my spica 1.5. i've upgraded to 2.1 firmware but i cant find the free version anymore in the market. i tried downloading the apk straight from smartkeyboardpro.com/files but it doesn't install on my phone when i open it. how can i install it? thanks!
Re: Can't Find?
There are probably several methods, but I use "Astro File Manager" to install apps stored on my SD card
terenceleechan
Re: Can't Find?
oh now i get it. the native file manager tool with the fw cant detect the apk. thanks cyril!
