Android minimal version?
rhruiz
- Phone: motorola milestone
What is the minimal version to run smart keyboard? i have an Android 2.0.0 (api level 5) and no versions of smart keyboard are shkwing in the market for me.
Re: Android minimal version?
2.0 is the minimal version. Where do you live ? Maybe you can try "Market Enabler" to see it, as others suggested
rhruiz
Hello Cyril,
I am from Brazil and I did try MarketEnabler with a couple of different operators but no luck. Not even the free version is showing up. I guess I will have to try again after the 2.0.1 update comes out
Evan
2.0.1 is out already. 2.1 is the one coming out soon. Or check out alldroid.org and you can get 2.1 now with a ton of cool stuff
rhruiz
Not yet for my South American Milestone, the methods availabe on alldroid.org will make me lose my 3GEvan wrote:2.0.1 is out already. 2.1 is the one coming out soon. Or check out alldroid.org and you can get 2.1 now with a ton of cool stuff
