I have another keyboard installed for hebrew language.
Usually i could swap keyboards by a long press on some key on the stock keyboard, it will bring up a menu asking me which keyboard i would like to use.
How do i do the same with Smart Keyboard Pro?
Sorry of this was asked before. tried searching and nothing came up,
How to change to a different keyboard?
Re: How to change to a different keyboard?
I will work on the doc, but it's written in http://android.cdeguet.net/ and in the app itself (when you click on the launcher icon)
Anyway I will add hebrew eventuallyThen go into any app with a text input box, do a long press in this input box, and you should see a popup menu with “Input method”. Click on “Input method”, and select “Smart Keyboard (Pro)” in the list.
Thanks for the fast reply here and for resolving my only issue
You have the best keyboard solution on the Android platform. worth every penny!
Any plans to support hebrew in a future release?
Hi I accidently hit something on my keyboard and it now has two letters per button ...how can I change it back to one letter per button?
You just did a "swipe left" to switch to compact qwerty. Just do it again twice (or change the "portrait mode" in the settings)
