dioes it work with the Motorola Android Pro?
fihner
- Phone: Android Pro
I got the trial app from the Android App Market and installed and made the necessary settings...All appears fine, but on long hold, I select INPUT METHOD and select the Smart Keyboard nothing happens. Is this possibly because the Android Pro phone has an external keyboard and will not allow this app to work ??? Need some advice, please.
Re: dioes it work with the Motorola Android Pro?
Yes that's because of a Motorola bug with the hard keyboard. You need to enable the advanced option "ignore hard keyboard" in smart keyboard settings.
erilon_34
When you buy Motorola set, then I suggest you to also buying Motorola EX115 skins for your mobile safety and protection.
