My droid 2 global with smart keyboard pro 4.4.1 did a switch on me and I have no clue what happened.. The mic icon button to the left of the spacebar key is now a ".com" button... even if i change back to stock keyboard; and, even after doing a Bootstrap Restore to a couple days ago when it was a microphoe icon button.. I reinstalled Google/voice search and no help... I went into settings and checked, unchecked, everything i could imagine with keyboard language section..
I am stumped..
Thank you in advance for any help....
help..mic icon changed to .com
Re: help..mic icon changed to .com
I had a similar problem a couple months back. Wipe the phone cache and davlik from recovery and then change the settings to how you would like it.
Via TT
Via TT
Okay, I did all that, and it did not work....
So again, I went back to settings, (Well, that actually IS what you suggested, so I guess it did work!),,,Anyway, I had the "Persistent domain key" checked... Kinda odd that it did not change back to what I had originally, when I did a Restore from bootstrapper.. I thought that also restored your keyboard settings?.. oh well, chalk one up for another successful solution..
Thank you!
Thank you!
