a question about a question mark
benpeleg
Post by benpeleg »
how cam i add a question mark button?i dont want the one with long press, like there a coma button, a period button,(of course i'm talking about the letters screen and not the symbols one) i want one for the question mark, is that even possible?
thanks a lot
Re: a question about a question mark
Isn't it enough to have it in the prediction bar?
benpeleg
Post by benpeleg »
i was not aware to that, i'll check it. anyway thanks for the quick reply
benpeleg
Post by benpeleg »
Is there any way to put it regularly in the prediction bar instead of the predicted words?
It should be the case if you kept the option "Suggest punctuations" enabled. Otherwise can you describe precisely what you do to NOT see punctuation signs in the prediction bar?
benpeleg
Post by benpeleg »
sorry about all the questions,but i didnt understand.i dont want the predicted word, i want only the punctuations in that bar, permanently, and i couldnt do it like you said...
awalkerz
Phone: LG Revolution 2.2.2
Post by awalkerz »
I see the punctuation options in the prediction bar after I hit the spacebar once after typing out a word. If you hit the spacebar again, you get the period automatically. If you hit the ? in the prediction bar, you get a ? but with a space between the end of the word and the ?. Like this: "Example ?" The default android keyboard recogonizes the ? needs to be right behind the word and removes the space.
Is this a setting I can change or is it just a qwirk of the keyboard?
awalkerz wrote:Is this a setting I can change
Yes, "swap punctuation"
