Smartkeyboard Tablet
- Phone: Samsung Epic 4G
Is there going to be a version of smart keyboard for honeycomb? I would really love to be able to use it on my tablet.
Re: Smartkeyboard Tablet
Why do you think another version is needed? Smart Keyboard works and has always worked on Honeycomb!
I would say otherwise.
Built in HC keyboard
Http://bayimg.com/pAIbaaADo
Vs
Smart Keyboard
http://bayimg.com/aaIcmaadO
For some reason input fields got bloated in size.
Same thing happens in the browsers adress field, extremely annoying.
Vs
Smart Keyboard
That's because you disabled the "no landscape fullscreen" option. Not sure why, as it should be on by default on tablets.
Jesus, fast respons time to the support
I was about to return and say that after uninstall and reinstall the problem was gone.
I'm pretty happy happy joy joy as of now
Thanks for a great keyboard !
Suggestion out of this,perhaps a restore original settings menu option or bringing it more to the front, couldn't seem to find one now when I searched.
