Thanks in advance
Arrow keys...
Arrow keys...
Hey everyone, just wondering if anyone can help me (very new to this!) - installed Smart Keyboard Pro, and the right arrow key doesn't work! The others do, just the right one. It registers the press, just doesn't move the cursor. Any ideas/suggestions/tips?
Thanks in advance
Thanks in advance
Re: Arrow keys...
Seems to work fine for me. I only have arrow keys enabled in landscape mode. Are you using that or portrait mode?
Re: Arrow keys...
Hi Nick, I'm using it in portrait, but it's the same in landscape too. My nephew has it on his HTC Incredible and it's fine! Can't fathom why it'd only be the right arrow key. Oh well!
Re: Arrow keys...
Well, this problem is... incredible
Seriously I have no real clue about where the problem could come from. Maybe another app you installed interferes with the keyboard.
Re: Arrow keys...
Haha, very good Cyril
it's a handy feature to have too. There was an update for it yesterday, but didn't change that. The mystery continues...
Re: Arrow keys...
I just tested mine in Portrait and works there too. So yes, a mystery indeed on yours. Have you tried reinstalling Smart Keyboard? Possible that some app is conflicting with it but a reinstall might overwrite whatever got messed up. I think once or twice I've had to do this for little issues.
Re: Arrow keys...
Thanks for the reply Nick. I haven't tried uninstalling/reinstalling, but it's worth a shot. Installed a couple of updates to it, but, alas, no difference.
I'll post the results here!
Best wishes all
Best wishes all
