need t9 option
macieellia2007
- Phone: droid eris 1.5
need t9 option
Need t9 option can u please ad this it would make this a complete app
Re: need t9 option
I will work on this, but do you mean T9 or compact QWERTY (ie 2 letters per key)
macieellia2007
Re: need t9 option
THe t 9 not the two letters that is so hard to use.
Make sure its tap mode and predictive text. Also what would be cool is too have
# pad that is setup like a calculator instead of having the
#s going across kid screen. ANd if ur able to be able to save words in the dictionary when using the
T 9. AS of now the other app I use the developer still hasn't done anything yet to do this and u always have to turn the phone to landscapes mode to type word into the dictionary to save words. SO thank u for considering this . KRista
macieellia2007
Re: need t9 option
NO I didn't see that I keep getting keep getting the across version ill look again
Re: need t9 option
It only works in numeric fields, for instance when you edit a phone number in the contact app.
macieellia2007
Re: need t9 option
IF u could put have it available all the time it would be perfect cause its so hard to use the across version mistakes happen all the time thanks
macieellia2007
Re: need t9 option
If u do decide to put the numeric keypad option available all the time i would have a button come up to search characters also. That' s what my droid eris has for standard keyboard option #s like on the phone and most used characters around in the empty spots and another main button to get to the other symbols. Its a great setup but the stock keyboard always goes to tap mode on google and other entrees which is annoying. So thanks for taking my suggestions trying to find a keyboard with all the goodies we like is hard to come by
Krista
Krista
Re: need t9 option
Usually, cotton mesh New England Patriots Wes Welker jerseys sell the most. However, silk and pure cotton New England Patriots Nike NFL T-shirts jerseys are also quite popular. Generally, jerseys are made from all kinds of cloth are available. Also, you can customize your own jerseys.
