Under PORTRAIT MODE, I've selected the T9 Layout, which brings the "N70" feel of keyboard.
If the keyboard is set to "QWERTY" the layout is perfect. I mean, no issues for me.
But..
T9 layout, which layout is set to "ABC[2], DEF[3], GHI[4], etc", I've found the right portion of the buttons not aligned well compared to the left portion of the keyboard. You can check it for yourself, and I don't know how to screenshot the layout for proof.
can you fix this? if not, it's ok. All the functions are well organized. Just that little alignment from the right portion.
