AutoText grayed out
kiwibird
- Phone: Archos 43 Froyo
AutoText grayed out
I have downloaded the paid version of the App, but the Custom AutoText option is grayed out. I tried to uninstall / reinstall, and it's still the same. Any ideas how to get it to work?
Re: AutoText grayed out
You first need to enable "show suggestions" option. But indeed "show suggestions" is no more required to use auto-text, I will fix in the next version (but you can still check the option to edit your auto-texts, and disable it again afterwards).
kiwibird
Thanks; that fixed the problem indeed.
