Traditional watch task is relatively single, that is the time.To complete the task requires time, minute hand clockwise, perhaps coupled with the power reserve indicator.Horological Machine No4 (HM4) Thunderbolt (thunder) table, also equipped with clockwise, the minute hand and a power storage indicating device, and has timing function, but the HM4 Thunderbolt table is not generally traditional type fake rolex.
Thunderbolt watches watchcase and movement totally into one, its design inspiration from the fields of aviation, although both are interdependent, cannot exist alone, but remain their excellent characteristics, and may be considered as independent works of art.
HM4 case to high-tech titanium alloy, it is lightweight and tough material characteristics; through to sapphire crystal made of table body of mirror, can see movement.Limited edition of HM4 Razzle Dazzle and Double Trouble creation thinking in Heroes Theme, pods are truly a rivet and nose art pattern, the inspiration from the two World War fighter; HM4 RT offers more luxury flying dream.
Replica Rolex Thunderbolt table movement after three years of painstaking effort and crystal, with a total of more than 300 components, to the regulator to the screw, any assembly is designed for this movement the special design.
The level of configuration of two main box spring to drive the two vertical gear, and power were sent to the display time and power storage two pods.However, if you want to through the mechanical function of simple description of the HM4 movement, as through pigment chemical composition described by French impressionist painter Renoir (Renoir) works like pale.
It is only with the heart can see, really appreciate the essence of HM4; through the middle clamp cabin with a sapphire crystal mirror, as well as the case is, the back window, we can enjoy appreciate belong exclusively to the HM4 complex, dynamic micro mechanical perfect delicate texture.
Thunderbolt avant-garde aerodynamic type clamp cabin uses titanium metal and sapphire crystal to create, design inspired by Maximilian B ü sser childhood love of aircraft assembly model, but the old model of course far less double clamp cabin design bold.
replica watches Double clamp cabin in the middle of inlaid with transparent sapphire crystal mirror eye-catching design, it takes more than 100 hours of machining and grinding, can be opaque solid crystal carved into delicate translucent curved composite panel, and also show the Thunderbolt movement's unique sense of beauty.
All components and each kind of shape with the technical requirements for this, no redundant, all the lines are poetic harmony.The connection lugs can ensure that the wearers of absolute comfort, with a high degree of recognition of the timekeeping function is the extra benefits.
HM4 Razzle Dazzle and Double Trouble each paragraph only limited issue 8, titanium alloy, sapphire crystal to create, hand-drawn and case on the nose art pattern; HM4 RT, limited edition of 18, with rose gold, titanium alloy and sapphire crystal created.
